Conference papers
Minimum detectable damage for stochastic subspace-based methods
Résumé : Detecting small and local damages on structures based on ambient vibrations is a major challenge in structural health monitoring. However, being able to identify the minimum damage is essential for quantifying the effectiveness of the instrumentation and for defining the limitations of low-frequency vibration monitoring in general. This paper shows how subspace-based methods could be used by engineers to predict the minimum damage that can be detected. The method employs a Gaussian subspace-based residual vector as a damage-sensitive criterion and evaluates its deviation from zero mean through two different statistical hypothesis tests, a parametric version and a non-parametric one. A sensitivity analysis is carried out to parametrize the deviation from the nominal state, and link it to physical parameters in a finite element model through the Fisher information matrix. This link can also be used to predict the minimum detectable damage, e.g. by prescribing a minimum probability of detection based on code-based reliability concepts. Ultimately, the developed theory is verified by means of a numerical example.
Document type :
Conference papers
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-02142994
Contributor : Michael Döhler Connect in order to contact the contributor
Submitted on : Wednesday, May 29, 2019 - 8:58:47 AM
Last modification on : Friday, February 4, 2022 - 3:20:10 AM
File
91_Mendler_Damage_detection.pd...
Identifiers
  • HAL Id : hal-02142994, version 1
Collections
Citation
Alexander Mendler, Saeid Allahdadian, Michael Dohler, Laurent Mevel, Carlos Ventura. Minimum detectable damage for stochastic subspace-based methods. IOMAC 2019 - 8th International Operational Modal Analysis Conference, May 2019, Copenhague, Denmark. pp.1-11. ⟨hal-02142994⟩
Share
Metrics
Record views
171
Files downloads
223
