P-FPT algorithms for bounded clique-width graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Algorithms Année : 2019
Recently, hardness results for problems in P were achieved using reasonable complexity theoretic assumptions such as the Strong Exponential Time Hypothesis. According to these assumptions, many graph theoretic problems do not admit truly subquadratic algorithms. A central technique used to tackle the difficulty of the above mentioned problems is fixed-parameter algorithms with polynomial dependency in the fixed parameter (P-FPT). Applying this technique to clique-width, an important graph parameter, remained to be done. In this paper we study several graph theoretic problems for which hardness results exist such as cycle problems, distance problems and maximum matching. We give hardness results and P-FPT algorithms, using clique-width and some of its upper bounds as parameters. We believe that our most important result is an algorithm in $O(k^4 · n + m)$-time for computing a maximum matching where $k$ is either the modular-width of the graph or the $P_4$-sparseness. The latter generalizes many algorithms that have been introduced so far for specific subclasses such as cographs. Our algorithms are based on preprocessing methods using modular decomposition and split decomposition. Thus they can also be generalized to some graph classes with unbounded clique-width.
hal-version-talg.pdf (657.68 Ko) Télécharger le fichier
hal-02152971 , version 1 (11-06-2019)
David Coudert, Guillaume Ducoffe, Alexandru Popa. P-FPT algorithms for bounded clique-width graphs. ACM Transactions on Algorithms, 2019, 15 (3), pp.1-57. ⟨10.1145/3310228⟩. ⟨hal-02152971⟩
205 Consultations
409 Téléchargements
