Reports
Introduce the nullptr constant
Jens Gustedt 1
1 CAMUS - Compilation pour les Architectures MUlti-coeurS
Inria Nancy - Grand Est, ICube - Laboratoire des sciences de l'ingénieur, de l'informatique et de l'imagerie
Abstract : Since more than a decade C++ has already replaced the problematic definition of NULL which might be either of integer type or void*. By using a new constant nullptr, they achieve a more constrained specification, that allows much better diagnosis of user code. We propose to integrate this concept into C as far as possible without putting much strain on implementations. This is a split-off of N2368 that builds on the approval of the "keywords" patches.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/hal-02167929
Contributor : Jens Gustedt Connect in order to contact the contributor
Submitted on : Friday, June 28, 2019 - 12:01:43 PM
Last modification on : Thursday, December 2, 2021 - 3:17:01 AM
File
n2394+appendix.pdf
Identifiers
  • HAL Id : hal-02167929, version 1
Citation
Jens Gustedt. Introduce the nullptr constant. [Research Report] N2394, ISO JTC1/SC22/WG14. 2019. ⟨hal-02167929⟩
Share
Metrics
Record views
118
Files downloads
517
