Parametric Timed Model Checking for Guaranteeing Timed Opacity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Information leakage can have dramatic consequences on systems security. Among harmful information leaks, the timing information leakage is the ability for an attacker to deduce internal information depending on the system execution time. We address the following problem: given a timed system, synthesize the execution times for which one cannot deduce whether the system performed some secret behavior. We solve this problem in the setting of timed automata (TAs). We first provide a general solution, and then extend the problem to parametric TAs, by synthesizing internal timings making the TA secure. We study decidability, devise algorithms, and show that our method can also apply to program analysis.
hal-02170527 , version 1 (02-07-2019)
Étienne André, Jun Sun. Parametric Timed Model Checking for Guaranteeing Timed Opacity. 17th International Symposium on Automated Technology for Verification and Analysis (ATVA 2019), Ming-Hsien Tsai, Oct 2019, Taipei, Taiwan. ⟨hal-02170527⟩
45 Consultations
0 Téléchargements
