Remaining Useful Life Estimation for Informed End of Life Management of Industrial Assets: A Conceptual Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The management of the End of Life phase of the lifecycle of industrial assets is more and more a relevant issue for companies dealing with aging assets. This paper provides a conceptual model that includes different aspects that should be considered by a comprehensive methodology to support an informed decision-making process in this regard. In particular, the work stems from the need of estimating the Remaining Useful Life (RUL) of an asset, for defining an Ageing Asset Strategy, through a multi-disciplinary approach instead of a purely technical one. To this end, the proposed model highlights the different End of Life types of an asset that should be considered for comprehensive RUL estimation methodology.
472851_1_En_42_Chapter.pdf (446.63 Ko) Télécharger le fichier
hal-02177879 , version 1 (09-07-2019)
Paternité
Marco Macchi, Irene Roda, Leonardo Toffoli. Remaining Useful Life Estimation for Informed End of Life Management of Industrial Assets: A Conceptual Model. IFIP International Conference on Advances in Production Management Systems (APMS), Aug 2018, Seoul, South Korea. pp.335-342, ⟨10.1007/978-3-319-99707-0_42⟩. ⟨hal-02177879⟩
82 Consultations
143 Téléchargements
