HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Study on the Dynamic Low Limit of Irrigation for Winter Wheat
Abstract : The concept of dynamic irrigation low limit (DILL) was proposed and the determination method of DILL was given based on crop-water model. The parameters of the crop-water model were calibrated with winter wheat experimental data of 2008 and 2009. The optimal irrigation scheduling of five typical years under different irrigation water supply were determined, which resulted in 58 groups of data on the average soil moisture content of main root zone (0–60 cm) before an irrigation, the corresponding irrigation time, and water supply. The results showed that, the crop yield under the irrigation times of 3 and 2 increased by 7.42% and 5.62% averaged from 2009 to 2013, and the economic benefit increased by 7.64% and 7.24% than those under the empirical irrigation practices, respectively. The irrigation forecast based on DILL provides an important method to implement and dynamically correct optimal irrigation scheduling under limited water supply.
Document type :
Conference papers
Complete list of metadata
Cited literature [52 references]  Display  Hide  Download
https://hal.inria.fr/hal-02180009
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, July 12, 2019 - 3:11:56 PM
Last modification on : Friday, July 12, 2019 - 3:12:28 PM
File
478221_1_En_17_Chapter.pdf
Identifiers
Citation
Hongzheng Shen, Yangren Wang. Study on the Dynamic Low Limit of Irrigation for Winter Wheat. 10th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2016, Dongying, China. pp.173-188, ⟨10.1007/978-3-030-06155-5_17⟩. ⟨hal-02180009⟩
Share
Metrics
Record views
23
Files downloads
6
