Absolute root separation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Experimental Mathematics Année : 2022
The absolute separation of a polynomial is the minimum nonzero difference between the absolute values of its roots. In the case of polynomials with integer coefficients, it can be bounded from below in terms of the degree and the height (the maximum absolute value of the coefficients) of the polynomial. We improve the known bounds for this problem and related ones. Then we report on extensive experiments in low degrees, suggesting that the current bounds are still very pessimistic.
1907.01232.pdf (270.58 Ko) Télécharger le fichier
hal-02185594 , version 1 (21-12-2023)
Yann Bugeaud, Andrej Dujella, Wenjie Fang, Tomislav Pejković, Bruno Salvy. Absolute root separation. Experimental Mathematics, 2022, 31 (3), pp.805-812. ⟨10.1080/10586458.2019.1699480⟩. ⟨hal-02185594⟩
107 Consultations
10 Téléchargements
