A Ciphertext-Policy Attribute-Based Encryption Based on Multi-valued Decision Diagram - Archive ouverte HAL Access content directly
Conference Papers Year : 2018
(1) , (1) , (1) , (1) , (1)
1
Ciphertext-policy attribute-based encryption (CP-ABE) is a kind of asymmetric encryption which is widely used in cyber-physical system and Internet of Things. In CP-ABE, access structure is an important component affecting the efficiency and performance greatly in several stages, such as encryption stage, key generation stage, decryption stage. However, the existing CP-ABE schemes have low efficiency because of the application of traditional access structures. In order to alleviate the aforementioned problems, this paper proposes a brand-new access structure based on multi-valued decision diagram (MDD). According to this access structure, we design a new CP-ABE scheme which performs better than many current schemes. First, our scheme supports multi-valued attributes directly. Second, the size of secret key is constant because it bears no relationship to the number of attributes. Third, the time complexity of decryption stage is O(1).
473854_1_En_30_Chapter.pdf (266.62 Ko) Télécharger le fichier
Dates and versions
hal-02197795 , version 1 (30-07-2019)
Attribution - CC BY 4.0
Identifiers
Cite
Shaowei Zhang, Long Li, Liang Chang, Tianlong Gu, Huadong Liu. A Ciphertext-Policy Attribute-Based Encryption Based on Multi-valued Decision Diagram. 10th International Conference on Intelligent Information Processing (IIP), Oct 2018, Nanning, China. pp.303-310, ⟨10.1007/978-3-030-00828-4_30⟩. ⟨hal-02197795⟩
43 View
58 Download
Share
