Conference papers
Multichannel Speech Enhancement Based on Time-frequency Masking Using Subband Long Short-Term Memory
Xiaofei Li 1 Radu Horaud 1
1 PERCEPTION - Interpretation and Modelling of Images and Videos
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
Abstract : We propose a multichannel speech enhancement method using along short-term memory (LSTM) recurrent neural network. The proposed method is developed in the short time Fourier transform (STFT) domain. An LSTM network common to all frequency bands is trained, which processes each frequency band individually by mapping the multichannel noisy STFT coefficient sequence to its corresponding STFT magnitude ratio mask sequence of one reference channel. This subband LSTM network exploits the differences between temporal/spatial characteristics of speech and noise, namely speech source is non-stationary and coherent, while noise is stationary and less spatially-correlated. Experiments with different types of noise show that the proposed method outperforms the baseline deep-learning-based full-band method and unsupervised method. In addition, since it does not learn the wideband spectral structure of either speech or noise, the proposed subband LSTM network generalizes very well to unseen speakers and noise types.
Complete list of metadatas
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-02264247
Contributor : Team Perception <>
Submitted on : Monday, October 14, 2019 - 5:55:01 PM
Last modification on : Friday, July 3, 2020 - 4:49:11 PM
Identifiers
Collections
Citation
Xiaofei Li, Radu Horaud. Multichannel Speech Enhancement Based on Time-frequency Masking Using Subband Long Short-Term Memory. IEEE Workshop on Applications of Signal Processing to Audio and Acoustics, Oct 2019, New Paltz, NY, United States. pp.298-302, ⟨10.1109/WASPAA.2019.8937218⟩. ⟨hal-02264247v2⟩
Share
Metrics
Record views
193
Files downloads
804
