Local conditions for triangulating submanifolds of Euclidean space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
In this paper, we consider the following setting: suppose that we are given a manifold in Rd with positive reach. Moreover assume that we have an embedded simplical complex A without boundary, whose vertex set lies on the manifold, is sufficiently dense and such that all simplices in A have sufficient quality. We prove that if, locally, interiors of the projection of the simplices onto the tangent space do not intersect, then A is a triangulation of the manifold, that is they are homeomorphic.
LocalConditionForHomeoSubmanifold_FinalVersion.pdf (297.17 Ko) Télécharger le fichier
hal-02267620 , version 1 (19-08-2019)
  • HAL Id : hal-02267620 , version 1
Jean-Daniel Boissonnat, Ramsay Dyer, Arijit Ghosh, André Lieutier, Mathijs Wintraecken. Local conditions for triangulating submanifolds of Euclidean space. 2019. ⟨hal-02267620⟩
130 Consultations
225 Téléchargements
