Abstract : Considering the increasing deployment of smart home IoT devices, their ownership is likely to change during their life-cycle. IoT devices, especially those used in smart home environments, contain privacy-sensitive user data, and any ownership change of such devices can result in privacy leaks. The problem arises when users are either not aware of the need to reset/reformat the device to remove any personal data, or not trained in doing it correctly as it can be unclear what data is kept where. In addition, if the ownership change is due to theft or loss, then there is no opportunity to reset. Although there has been a lot of research on security and privacy of IoT and smart home devices, to the best of our knowledge, there is no prior work specifically on automatically securing ownership changes. We present a system called
for securely handling ownership change of IoT devices.
combines authentication (of both users and their smartphone), profile management, data protection by encryption, and automatic inference of ownership change. For the latter, we use a simple technique that leverages the context of a device. Finally, as a proof of concept, we develop a prototype that implements
inferring ownership change from changes in the WiFi SSID. The performance evaluation of the prototype shows that
has minimal overhead and is compatible with the dominant IoT boards on the market.
https://hal.inria.fr/hal-02271658 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, August 27, 2019 - 10:22:57 AM Last modification on : Wednesday, November 3, 2021 - 6:55:33 AM Long-term archiving on: : Saturday, January 11, 2020 - 2:09:36 AM
Md Sakib Nizam Khan, Samuel Marchal, Sonja Buchegger, N. Asokan. chownIoT: Enhancing IoT Privacy by Automated Handling of Ownership Change. Eleni Kosta; Jo Pierson; Daniel Slamanig; Simone Fischer-Hübner; Stephan Krenn. Privacy and Identity Management. Fairness, Accountability, and Transparency in the Age of Big Data : 13th IFIP WG 9.2, 9.6/11.7, 11.6/SIG 9.2.2 International Summer School, Vienna, Austria, August 20-24, 2018, Revised Selected Papers, AICT-547, Springer International Publishing, pp.205-221, 2019, IFIP Advances in Information and Communication Technology, 978-3-030-16743-1. ⟨10.1007/978-3-030-16744-8_14⟩. ⟨hal-02271658⟩
