GDPR and the Concept of Risk: - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2019
Katerina Demetzou
  • Fonction : Auteur
  • PersonId : 1052857
The prominent position of risk in the GDPR has raised questions as to the meaning this concept should be given in the field of data protection. This article acknowledges the value of extracting information from the GDPR and using this information as means of interpretation of risk. The ‘role’ that risk holds in the GDPR as well as the ‘scope’ given to the concept, are both examined and provide the reader with valuable insight as to the legislature’s intentions with regard to the concept of risk. The article also underlines the importance of taking into account new technologies used in personal data processing operations. Technologies such as IoT, AI, algorithms, present characteristics (e.g. complexity, autonomy in behavior, processing and generation of vast amounts of personal data) that influence our understanding of risk in data protection in various ways.
479119_1_En_10_Chapter.pdf (507.59 Ko) Télécharger le fichier
hal-02271667 , version 1 (27-08-2019)
Paternité
Katerina Demetzou. GDPR and the Concept of Risk:. Eleni Kosta; Jo Pierson; Daniel Slamanig; Simone Fischer-Hübner; Stephan Krenn. Privacy and Identity Management. Fairness, Accountability, and Transparency in the Age of Big Data : 13th IFIP WG 9.2, 9.6/11.7, 11.6/SIG 9.2.2 International Summer School, Vienna, Austria, August 20-24, 2018, Revised Selected Papers, AICT-547, Springer International Publishing, pp.137-154, 2019, IFIP Advances in Information and Communication Technology, 978-3-030-16743-1. ⟨10.1007/978-3-030-16744-8_10⟩. ⟨hal-02271667⟩
126 Consultations
189 Téléchargements
