GDPR Transparency Requirements and Data Privacy Vocabularies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2019
This tutorial introduced participants to the transparency requirements of the General Data Protection Regulation (GDPR) [35]. Therein, it was explored together with the attendees whether technical specifications can be valuable to support transparency in favour of a data subject whose personal information is being processed. In the context of the discussions, past and present international efforts were examined that focus on data privacy vocabularies and taxonomies as basis work to enable effective enforcement of data handling policies. One example of a current undertaking in this area is the W3C Data Privacy Vocabularies and Controls Community Group (DPVCG) which aims at developing a taxonomy of privacy terms aligned to the GDPR, which encompasses personal data categories, processing purposes, events of disclosures, consent, and processing operations. During the tutorial session, the potential of such efforts was discussed among the participants, allowing for conclusions about the need to re-align and update past research in this area to the General Data Protection Regulation.
479119_1_En_7_Chapter.pdf (404.3 Ko) Télécharger le fichier
hal-02271670 , version 1 (27-08-2019)
Paternité
Eva Schlehahn, Rigo Wenning. GDPR Transparency Requirements and Data Privacy Vocabularies. Eleni Kosta; Jo Pierson; Daniel Slamanig; Simone Fischer-Hübner; Stephan Krenn. Privacy and Identity Management. Fairness, Accountability, and Transparency in the Age of Big Data : 13th IFIP WG 9.2, 9.6/11.7, 11.6/SIG 9.2.2 International Summer School, Vienna, Austria, August 20-24, 2018, Revised Selected Papers, AICT-547, Springer International Publishing, pp.95-113, 2019, IFIP Advances in Information and Communication Technology, 978-3-030-16743-1. ⟨10.1007/978-3-030-16744-8_7⟩. ⟨hal-02271670⟩
132 Consultations
358 Téléchargements
