Southern Theories in ICT4D - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
David Kreps
  • Fonction : Auteur
  • PersonId : 999744
Julian M. Bass
  • Fonction : Auteur
  • PersonId : 1023936
This paper suggests that the dominance of northern research paradigms in ICT4D may be viewed as a continuation of colonial sway over the endeavors of the global South. The notion of Southern Theory - as introduced in the work of Raewyn Connell, the Comaroffs, and others - may be a route by which researchers in the global South can reclaim the intellectual territory of ICT4D, with indigenous and regional research paradigms and theories rather than those simply absorbed from the global North.
484106_1_En_1_Chapter.pdf (94.35 Ko) Télécharger le fichier
hal-02281327 , version 1 (09-09-2019)
Paternité
David Kreps, Julian M. Bass. Southern Theories in ICT4D. 15th International Conference on Social Implications of Computers in Developing Countries (ICT4D), May 2019, Dar es Salaam, Tanzania. pp.3-13, ⟨10.1007/978-3-030-19115-3_1⟩. ⟨hal-02281327⟩
66 Consultations
43 Téléchargements
