An iterative frequency-sweeping approach for stability analysis of linear systems with multiple delays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Mathematical Control and Information Année : 2019
In this article, we study the stability of linear systems with multiple (incommensurate) delays, by extending a recently proposed frequency-sweeping approach. First, we consider the case where only one delay parameter is free while the others are fixed. The complete stability w.r.t. the free delay parameter can be systematically investigated by proving an appropriate invariance property. Next, we propose an iterative frequency-sweeping approach to study the stability under any given multiple delays. Moreover, we may effectively analyse the asymptotic behaviour of the critical imaginary roots (if any) w.r.t. each delay parameter, which provides a possibility for stabilizing the system through adjusting the delay parameters. The approach is simple (graphical test) and can be applied systematically to the stability analysis of linear systems including multiple delays. A deeper discussion on its implementation is also proposed. Finally, various numerical examples complete the presentation.
Automatique
LXGIMAPaper2019.pdf (1.13 Mo) Télécharger le fichier
hal-02281960 , version 1 (09-03-2021)
Xu-Guang Li, Silviu-Iulian Niculescu, Arben Cela. An iterative frequency-sweeping approach for stability analysis of linear systems with multiple delays. IMA Journal of Mathematical Control and Information, 2019, 36 (02), pp.379-398. ⟨10.1093/imamci/dnx050⟩. ⟨hal-02281960⟩
119 Consultations
82 Téléchargements
