Escaping the Streetlight Effect: Semantic Hypermedia Search Enhances Autonomous Behavior in the Web of Things - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The integration of systems of autonomous agents in Web of Things (WoT) environments is a promising approach to provide and distribute intelligence in worldwide pervasive systems. A central problem then is to enable autonomous agents to discover heterogeneous resources in large-scale, dynamic WoT environments. This is true in particular if an environment relies on open-standards and evolves rapidly requiring agents to adapt their behavior to achieve their goals. To this end, we developed a search engine for the WoT that allows autonomous agents to perform approximate search queries in order to find relevant resources in their environment in (weak) real time. The search engine crawls dynamic WoT environments to discover and index device metadata described with the W3C WoT Thing Description, and exposes a SPARQL endpoint that agents can use for approximate search. To demonstrate the feasibility of our approach, we implemented a prototype application for the maintenance of industrial robots in worldwide manufacturing systems. The prototype demonstrates that our semantic hypermedia search engine enhances the flexibility and agility of autonomous agents in the WoT.
IoT2019_paper_89_author_version.pdf (569.89 Ko) Télécharger le fichier
hal-02289497 , version 1 (16-09-2019)
Simon Bienz, Andrei Ciortea, Simon Mayer, Fabien Gandon, Olivier Corby. Escaping the Streetlight Effect: Semantic Hypermedia Search Enhances Autonomous Behavior in the Web of Things. IoT 2019 - 9th International Conference on the Internet of Things, Oct 2019, Bilbao, Spain. ⟨10.1145/3365871.3365901⟩. ⟨hal-02289497⟩
125 Consultations
258 Téléchargements
