New interface
Conference papers
A Structure Based Multiple Instance Learning Approach for Bacterial Ionizing Radiation Resistance Prediction
Abstract : Ionizing-radiation-resistant bacteria (IRRB) could be used for bioremediation of radioactive wastes and in the therapeutic industry. Limited computational works are available for the prediction of bacterial ionizing radiation resistance (IRR). In this work, we present ABClass, an in silico approach that predicts if an unknown bacterium belongs to IRRB or ionizing-radiation-sensitive bacteria (IRSB). This approach is based on a multiple instance learning (MIL) formulation of the IRR prediction problem. It takes into account the relation between semantically related instances across bags. In ABClass, a preprocessing step is performed in order to extract substructures/motifs from each set of related sequences. These motifs are then used as attributes to construct a vector representation for each set of sequences. In order to compute partial prediction results, a discriminative classifier is applied to each sequence of the unknown bag and its correspondent related sequences in the learning dataset. Finally, an aggregation method is applied to generate the final result. The algorithm provides good overall accuracy rates. ABClass can be downloaded at the following link: http://homepages.loria.fr/SAridhi/software/MIL/.
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/hal-02307048
Contributor : Sabeur Aridhi Connect in order to contact the contributor
Submitted on : Monday, October 7, 2019 - 11:41:32 AM
Last modification on : Wednesday, February 2, 2022 - 3:57:43 PM
File
Zoghlami et al KES 2019.pdf
Identifiers
  • HAL Id : hal-02307048, version 1
Citation
Manel Zoghlami, Sabeur Aridhi, Mondher Maddouri, Engelbert Mephu Nguifo. A Structure Based Multiple Instance Learning Approach for Bacterial Ionizing Radiation Resistance Prediction. KES 2019 - 23rd International Conference on Knowledge-Based and Intelligent Information & Engineering Systems, Sep 2019, Budapest, Hungary. ⟨hal-02307048⟩
Share
Metrics
Record views
36
Files downloads
76
