On the Performance of ARM TrustZone - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The TrustZone technology, available in the vast majority of recent Arm processors, allows the execution of code inside a so-called secure world. It effectively provides hardware-isolated areas of the processor for sensitive data and code, i.e., a trusted execution environment (TEE). The Op-Tee framework provides a collection of toolchain, open-source libraries and secure kernel specifically geared to develop applications for TrustZone. This paper presents an in-depth performance- and energy-wise study of TrustZone using the Op-Tee framework, including secure storage and the cost of switching between secure and unsecure worlds, using emulated and hardware measurements.
485766_1_En_9_Chapter.pdf (1.45 Mo) Télécharger le fichier
hal-02319569 , version 1 (18-10-2019)
Paternité
Julien Amacher, Valerio Schiavoni. On the Performance of ARM TrustZone. 19th IFIP International Conference on Distributed Applications and Interoperable Systems (DAIS), Jun 2019, Kongens Lyngby, Denmark. pp.133-151, ⟨10.1007/978-3-030-22496-7_9⟩. ⟨hal-02319569⟩
100 Consultations
171 Téléchargements
