Sampled-Data Observers: Scarce Arbitrarly Large Sampling Intervals - Archive ouverte HAL Access content directly
Conference Papers Year :
(1, 2)
1
2
Continuous-time systems with discrete measurements are considered. It is shown that the technique of [7] can be used to design converging observers in the case where the size of some intervals between 2 measurements is larger than the upper bound ensuring convergence of the observer that is provided in [7]. A scarcety condition on these intervals is exhibited. This result is established through a recent stability analysis technique called trajectory based approach.
fmverconf.pdf (191.06 Ko) Télécharger le fichier
Dates and versions
hal-02342668 , version 1 (01-11-2019)
Identifiers
  • HAL Id : hal-02342668 , version 1
Cite
Frédéric Mazenc. Sampled-Data Observers: Scarce Arbitrarly Large Sampling Intervals. ICTSTCC 2019 - 23rd International Conference on System Theory, Control and Computing, Oct 2019, Sinaia, Romania. ⟨hal-02342668⟩
36 View
160 Download
Share
