Topological Analysis of the 2D von Kármán Street - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2019
Topology based analysis and feature tracking is a well studied area. In this work, we focus exclusively on a dataset called the von Kármán street, and apply topology-based methods to understand its vortices. For this analysis, we adapt the recently proposed edit distance between merge trees. We discern several interesting results. One, we observe spatial periodicity between the vortices, alternating every half-cycle. Two, we observe a distinct difference in spatial probability of vortex regions during a half-cycle. Further, we compare the accuracy of our spatial probability with an off-the-shelf machine learning approach.
Analysis_of_the_2D_von_Karman_street.pdf (1.35 Mo) Télécharger le fichier
hal-02344001 , version 1 (03-11-2019)
hal-02344001 , version 2 (07-02-2020)
hal-02344001 , version 3 (10-05-2020)
  • HAL Id : hal-02344001 , version 3
Adhitya Kamakshidasan, Vijay Natarajan. Topological Analysis of the 2D von Kármán Street. VIS, 2019, Vancouver, Canada. ⟨hal-02344001v3⟩
84 Consultations
113 Téléchargements
