Efficient Diffusion on Region Manifolds: Recovering Small Objects with Compact CNN Representations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Query expansion is a popular method to improve the quality of image retrieval with both conventional and CNN representations. It has been so far limited to global image similarity. This work focuses on diffusion, a mechanism that captures the image manifold in the feature space. The diffusion is carried out on descriptors of overlapping image regions rather than on a global image descriptor like in previous approaches. An efficient off-line stage allows optional reduction in the number of stored regions. In the on-line stage, the proposed handling of unseen queries in the indexing stage removes additional computation to adjust the precomputed data. We perform diffusion through a sparse linear system solver, yielding practical query times well below one second. Experimentally, we observe a significant boost in performance of image retrieval with compact CNN descriptors on standard benchmarks, especially when the query object covers only a small part of the image. Small objects have been a common failure case of CNN-based retrieval.
1611.05113.pdf (1.69 Mo) Télécharger le fichier
hal-02370330 , version 1 (19-11-2019)
Ahmet Iscen, Giorgos Tolias, Yannis Avrithis, Teddy Furon, Ondrej Chum. Efficient Diffusion on Region Manifolds: Recovering Small Objects with Compact CNN Representations. 2016. ⟨hal-02370330⟩
37 Consultations
126 Téléchargements
