Conference papers
Algebraic XOR-RKA-Secure Pseudorandom Functions from Post-Zeroizing Multilinear Maps
Michel Abdalla 1 Fabrice Benhamouda 2 Alain Passelègue 3
1 CASCADE - Construction and Analysis of Systems for Confidentiality and Authenticity of Data and Entities
DI-ENS - Département d'informatique - ENS Paris, CNRS - Centre National de la Recherche Scientifique : UMR 8548, Inria de Paris
3 ARIC - Arithmetic and Computing
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : Due to the vast number of successful related-key attacks against existing block-ciphers, related-key security has become a common design goal for such primitives. In these attacks, the adversary is not only capable of seeing the output of a function on inputs of its choice, but also on related keys. At Crypto 2010, Bellare and Cash proposed the first construction of a pseudorandom function that could provably withstand such attacks based on standard assumptions. Their construction, as well as several others that appeared more recently, have in common the fact that they only consider linear or polynomial functions of the secret key over complex groups. In reality, however, most related-key attacks have a simpler form, such as the XOR of the key with a known value. To address this problem, we propose the first construction of RKA-secure pseudorandom function for XOR relations. Our construction relies on multilinear maps and, hence, can only be seen as a feasibility result. Nevertheless, we remark that it can be instantiated under two of the existing multilinear-map candidates since it does not reveal any encodings of zero. To achieve this goal, we rely on several techniques that were used in the context of program obfuscation, but we also introduce new ones to address challenges that are specific to the related-key-security setting.
Document type :
Conference papers
Complete list of metadata
Cited literature [44 references]  Display  Hide  Download
https://hal.inria.fr/hal-02375594
Contributor : Michel Abdalla Connect in order to contact the contributor
Submitted on : Thursday, November 12, 2020 - 4:58:24 PM
Last modification on : Wednesday, June 8, 2022 - 12:50:03 PM
Long-term archiving on: : Saturday, February 13, 2021 - 8:11:17 PM
File
main.pdf
Identifiers
Collections
Citation
Michel Abdalla, Fabrice Benhamouda, Alain Passelègue. Algebraic XOR-RKA-Secure Pseudorandom Functions from Post-Zeroizing Multilinear Maps. ASIACRYPT 2019 - 25th International Conference on the Theory and Application of Cryptology and Information Security, Dec 2019, Kobe, Japan. pp.386-412, ⟨10.1007/978-3-030-34621-8_14⟩. ⟨hal-02375594⟩
Share
Metrics
Record views
435
Files downloads
64
