Symmetry-Based Disentangled Representation Learning requires Interaction with Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Finding a generally accepted formal definition of a disentangled representation in the context of an agent behaving in an environment is an important challenge towards the construction of data-efficient autonomous agents. Higgins et al. (2018) recently proposed Symmetry-Based Disentangled Representation Learning, a definition based on a characterization of symmetries in the environment using group theory. We build on their work and make observations, theoretical and empirical, that lead us to argue that Symmetry-Based Disentangled Representation Learning cannot only be based on static observations: agents should interact with the environment to discover its symmetries. Our experiments can be reproduced in Colab and the code is available on GitHub.
1904.00243.pdf (1001.06 Ko) Télécharger le fichier
hal-02379399 , version 1 (25-11-2019)
Hugo Caselles-Dupré, Michael Garcia-Ortiz, David Filliat. Symmetry-Based Disentangled Representation Learning requires Interaction with Environments. NeurIPS 2019 6 Neural Information Processing Conference, Dec 2019, Vancouver, Canada. ⟨hal-02379399⟩
95 Consultations
57 Téléchargements
