Accuracy assessment of the Non-Ideal Computational Fluid Dynamics model for siloxane MDM from the open-source SU2 suite - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Mechanics - B/Fluids Année : 2020
The first-ever accuracy assessment of a computational model for Non-Ideal Compressible-Fluid Dynamics (NICFD) flows is presented. The assessment relies on a comparison between numerical predictions, from the open-source suite SU2, and pressure and Mach number measurements of compressible fluid flows in the non-ideal regime. Namely, measurements regard supersonic flows of siloxane MDM (Octamethyltrisiloxane, C 8 H 24 O 2 Si 3) vapor expanding along isentropes in the close proximity of the liquid-vapor saturation curve. The model accuracy assessment takes advantage of an Uncertainty Quantification (UQ) analysis, to compute the variability of the numerical solution with respect the uncertainties affecting the test-rig operating conditions. This allows for an uncertainty-based assessment of the accuracy of numerical predictions. The test set is representative of typical operating conditions of Organic Rankine Cycle systems and it includes compressible flows expanding through a converging-diverging nozzle in mildly-to-highly non-ideal conditions. All the considered flows are well represented by the computational model. Therefore, the reliability of the numerical implementation and the predictiveness of the NICFD model are confirmed.
1-s2.0-S099775461830712X-main-3.pdf (1.09 Mo) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-02389668 , version 1 (09-12-2019)
Giulio Gori, Marta Zocca, Giorgia Cammi, Andrea Spinelli, Pietro Marco Congedo, et al.. Accuracy assessment of the Non-Ideal Computational Fluid Dynamics model for siloxane MDM from the open-source SU2 suite. European Journal of Mechanics - B/Fluids, 2020, 79, pp.109-120. ⟨10.1016/j.euromechflu.2019.08.014⟩. ⟨hal-02389668⟩
115 Consultations
195 Téléchargements
