Aggregate Cash Systems: A Cryptographic Investigation of Mimblewimble - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mimblewimble is an electronic cash system proposed by an anonymous author in 2016. It combines several privacy-enhancing techniques initially envisioned for Bitcoin, such as Confidential Transactions (Maxwell, 2015), non-interactive merging of transactions (Saxena, Misra, Dhar, 2014), and cut-through of transaction inputs and outputs (Maxwell, 2013). As a remarkable consequence, coins can be deleted once they have been spent while maintaining public verifiability of the ledger, which is not possible in Bitcoin. This results in tremendous space savings for the ledger and efficiency gains for new users, who must verify their view of the system. In this paper, we provide a provable-security analysis for Mimblewimble. We give a precise syntax and formal security definitions for an abstraction of Mimblewimble that we call an aggregate cash system. We then formally prove the security of Mimblewimble in this definitional framework. Our results imply in particular that two natural instantiations (with Pedersen commitments and Schnorr or BLS signatures) are provably secure against inflation and coin theft under standard assumptions.
Fichier non déposé
hal-02396305 , version 1 (05-12-2019)
Georg Fuchsbauer, Michele Orrù, Yannick Seurin. Aggregate Cash Systems: A Cryptographic Investigation of Mimblewimble. Advances in Cryptology - EUROCRYPT 2019, May 2019, Darmstadt, Germany. ⟨10.1007/978-3-030-17653-2_22⟩. ⟨hal-02396305⟩
240 Consultations
0 Téléchargements
