On the Expressivity and Applicability of Model Representation Formalisms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A number of first-order calculi employ an explicit model representation formalism in support of non-redundant inferences and for detecting satisfiability. Many of these formalisms can represent infinite Herbrand models. The first-order fragment of monadic, shallow, linear, Horn (MSLH) clauses, is such a formalism used in the approximation refinement calculus (AR). Our first result is a finite model property for MSLH clause sets. Therefore, MSLH clause sets cannot represent models of clause sets with inherently infinite models. Through a translation to tree automata, we further show that this limitation also applies to the linear fragments of implicit generalizations, which is the formalism used in the model-evolution calculus (ME), to atoms with disequality constraints, the formalisms used in the non-redundant clause learning calculus (NRCL), and to atoms with membership constraints, a formalism used for example in decision procedures for algebraic data types. Although these formalisms cannot represent models of clause sets with inherently infinite models, through an additional approximation step they can. This is our second main result. For clause sets including the definition of an equivalence relation with the help of an additional, novel approximation, called reflexive relation splitting, the approximation refinement calculus can automatically show satisfiability through the MSLH clause set formalism.
frocos19.pdf (351.12 Ko) Télécharger le fichier
hal-02406605 , version 1 (12-12-2019)
Andreas Teucke, Marco Voigt, Christoph Weidenbach. On the Expressivity and Applicability of Model Representation Formalisms. FroCoS 2019 - 12th International Symposium on Frontiers of Combining Systems, 2019, London, United Kingdom. pp.22-39, ⟨10.1007/978-3-030-29007-8_2⟩. ⟨hal-02406605⟩
20 Consultations
66 Téléchargements
