Characterization of Daily Glycemic Variability in Subjects with Type 1 Diabetes Using a Mixture of Metrics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Diabetes Technology and Therapeutics Année : 2020
Background: Glycemic variability is an important component of glycemic control for patients with type 1 diabetes. The inadequacy of existing measurements lies in the fact that they view the variability from different aspects, so that no consensus has been reached among physicians as to which metrics to use in practice. Moreover, although glycemic variability, from one day to another, can show very different patterns, very few metrics have been dedicated to daily evaluations.
Methods: A reference (stable-glycemia) statistical model is built based on a combination of daily computed canonical glycemic control metrics including variability. The metrics are computed for subjects from the TRIMECO islet transplantation trial, selected when their β-score (composite score for grading success) ≥ 6 after a transplantation. Then, for any new daily glycemia recording, its likelihood with respect to this reference model provides a multi-metric score of daily glycemic variability severity. In addition, determining the likelihood value that best separates the daily glycemia with β-score=0 from that with β-score>=6, we propose an objective decision rule to classify daily glycemia into "stable" or "unstable".
Results: The proposed characterization framework integrates multiple standard metrics and provides us a comprehensive daily glycemic variability index, based on which, long term variability evaluations and investigations on the implicit link between variability and β-score can be carried out. Evaluation, in a daily glycemic variability classification task, shows that the proposed method is highly concordant to the experience of diabetologists.
Conclusion: A multivariate statistical model is proposed to characterize the daily glycemic variability of subjects with type 1 diabetes. The model has the advantage to provide a single variability score that gathers the information power of a number of canonical scores, too partial to be used individually. A reliable decision rule to classify daily variability measurements into stable or unstable is also provided.
DTT4HAL.pdf (6.91 Mo) Télécharger le fichier
hal-02415078 , version 1 (17-12-2019)
Fei Zheng, Manon Jalbert, Florence Forbes, Stephane Bonnet, Anne Wojtusciszyn, et al.. Characterization of Daily Glycemic Variability in Subjects with Type 1 Diabetes Using a Mixture of Metrics. Diabetes Technology and Therapeutics, 2020, 22 (4), pp.301-313. ⟨10.1089/dia.2019.0250⟩. ⟨hal-02415078⟩
120 Consultations
131 Téléchargements
