Factorization Method for Imaging a Local Perturbation in Inhomogeneous Periodic Layers from Far Field Measurements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inverse Problems and Imaging Année : 2020
We analyze the Factorization method to reconstruct the geometry of a local defect in a periodic absorbing layer using almost only incident plane waves at a fixed frequency. A crucial part of our analysis relies on the consideration of the range of a carefully designed far field operator, which characterizes the geometry of the defect. We further provide some validating numerical results in a two dimensional setting.
paper_Final.pdf (878.41 Ko) Télécharger le fichier
hal-02416496 , version 1 (17-12-2019)
Houssem Haddar, Alexander Konschin. Factorization Method for Imaging a Local Perturbation in Inhomogeneous Periodic Layers from Far Field Measurements. Inverse Problems and Imaging , 2020, 14 (1), pp.133-152. ⟨10.3934/ipi.2019067⟩. ⟨hal-02416496⟩
121 Consultations
134 Téléchargements
