Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Global asymptotic stability of a genetic negative feedback loop with an affine control
Lucie Chambon 1 Jean-Luc Gouzé 1
1 BIOCORE - Biological control of artificial ecosystems
CRISAM - Inria Sophia Antipolis - Méditerranée , INRA - Institut National de la Recherche Agronomique, LOV - Laboratoire d'océanographie de Villefranche
Abstract : Genetic negative feedback loops are essential and recurrent biological motifs. They are traditionally described with N-dimensional competitive dynamical systems, composed of highly non-linear Hill functions. The stability property of their unique steady state usually determines the global dynamical behavior: homeostasis under stability or emergence of oscillations. When homeostasis conditions are disrupted, undesired oscillations can emerge and may lead to various diseases. This paper presents a classical affine control strategy that is able to stabilize the unstable steady state of the disrupted system and suppress undesired oscillations. For biological purpose, this control is designed as simple as possible in order to reduce the use of devices and the complexity of the biological setup. For this reason, the control law only depends on the measurement of a unique gene and only acts on its own expression. Due to the complexity of this controlled dynamical system, a new methodology, based on the construction of successive hyperrectangles of the state space that act as Lyapunov function level-sets, is proposed in order to prove global convergence and global stability results. Despite its apparent simplicity, this affine control law is shown to globally stabilize the disrupted system and recover homeostasis.
Document type :
Conference papers
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-02418431
Contributor : Jean-Luc Gouzé Connect in order to contact the contributor
Submitted on : Wednesday, December 18, 2019 - 6:00:59 PM
Last modification on : Saturday, June 25, 2022 - 11:41:50 PM
Long-term archiving on: : Thursday, March 19, 2020 - 9:48:18 PM
File
CDC19_1007_FI.pdf
Identifiers
  • HAL Id : hal-02418431, version 1
  • WOS : 000560779002101
Citation
Lucie Chambon, Jean-Luc Gouzé. Global asymptotic stability of a genetic negative feedback loop with an affine control. CDC 2019 - 58th IEEE Conference on Decision and Control, Dec 2019, Nice, France. ⟨hal-02418431⟩
Share
Metrics
Record views
58
Files downloads
169
