Risk Sources Affecting the Asset Management Decision-Making Process in Manufacturing: A Systematic Review of the Literature - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Adalberto Polenghi
  • Fonction : Auteur
  • PersonId : 1061528
Irene Roda
  • Fonction : Auteur
  • PersonId : 991434
Marco Macchi
  • Fonction : Auteur
  • PersonId : 991431
Paolo Trucco
  • Fonction : Auteur
  • PersonId : 991633
Asset Management (AM) is promising for value creation from assets in the long term. A major concern to this end relates with the capabilities to achieve effective AM decision-making at every organisational level, i.e. operational, tactical, and strategical. Therefore, the goal of this research, grounded on a systematic literature review, is to identify which are the main sources of uncertainty that may influence the achievement of AM system related objectives and, as such, should be taken into consideration in a risk-informed decision-making process. Taking the manufacturing sector as a reference, the risk sources addressed by the extant literature are identified and mapped against a reference classification scheme. As a result, the research offers a comprehensive framework where risk sources, affecting the AM decision-making process, are systematically mapped. Information management is found to be the main risk source when making asset-related decisions.
489100_1_En_35_Chapter.pdf (260.26 Ko) Télécharger le fichier
hal-02419201 , version 1 (19-12-2019)
Paternité
Adalberto Polenghi, Irene Roda, Marco Macchi, Paolo Trucco. Risk Sources Affecting the Asset Management Decision-Making Process in Manufacturing: A Systematic Review of the Literature. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2019, Austin, TX, United States. pp.274-282, ⟨10.1007/978-3-030-30000-5_35⟩. ⟨hal-02419201⟩
45 Consultations
136 Téléchargements
