A Competence-Based Description of Employees in Reconfigurable Manufacturing Systems - Archive ouverte HAL Access content directly
Conference Papers Year : 2019
(1) , (1) , (1)
1
The increasing demand for customer-specific, cost-effective products with shorter production times is shaping the industrial production environment. Therefore, both human workers and machines must react to these changes with greater flexibility and productivity. This paper shows a procedure to plan the employee ideally into the Reconfigurable Manufacturing Systems (RMS). The approach systematizes the competences of employees and enables an assessment of different expertise levels to finally realize a flexible integration of them into the constantly changing work environment. Therefore, the competencies of employees must be opposed with the needed skills so that the work processes can be executed adequate according to the product requirements. When this procedure is finally described digitally, companies will be able to realize a flexible workforce planning in the RMS, which is not possible so far.
489100_1_En_33_Chapter.pdf (758.12 Ko) Télécharger le fichier
Dates and versions
hal-02419246 , version 1 (19-12-2019)
Attribution - CC BY 4.0
Identifiers
Cite
Svenja Korder, Barbara Tropschuh, Gunther Reinhart. A Competence-Based Description of Employees in Reconfigurable Manufacturing Systems. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2019, Austin, TX, United States. pp.257-264, ⟨10.1007/978-3-030-30000-5_33⟩. ⟨hal-02419246⟩
38 View
40 Download
Share
