2Stellenbosch University (Stellenbosch University
Private Bag X1,
Matieland, 7602,
Stellenbosch, South Africa - South Africa)
Abstract : The increased environmental awareness of these days urge companies towards energy efficient production. This work focuses on the consideration of power consumption since the design stage of a production system. A new Assembly Line Balancing Problem is introduced in which each task is associated with a power consumption. The aim is to find an assignment of tasks to workstations that minimizes the overall power peak while complying with given maximum cycle time and number of workstations. An Integer Linear Programming formulation is proposed and tested on benchmark instances enhanced with power features. Numerical results are discussed.
https://hal.inria.fr/hal-02419251 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, December 19, 2019 - 1:17:07 PM Last modification on : Friday, December 20, 2019 - 1:45:56 AM Long-term archiving on: : Friday, March 20, 2020 - 6:13:24 PM
Marius Greger, Daniel Palm, Louis Louw, Konrad Von Leipzig. Simple Assembly Line Balancing Problem with Power Peak Minimization. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2019, Austin, United States. pp.239-247, ⟨10.1007/978-3-030-30000-5_31⟩. ⟨hal-02419251⟩
