Stochastic weather generator for the design and reliability evaluation of desalination systems with Renewable Energy Sources - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Renewable Energy Année : 2020
The operation of Renewable Energy Sources (RES) systems is highly affected by the continuously changing meteorological conditions and the design of a RES system has to be robust to the unknown weather conditions that it will encounter during its lifetime. In this paper, the use of Stochastic Weather Generators (SWGENs) is introduced for the optimal design and reliability evaluation of hybrid Photovoltaic/Wind-Generator systems providing energy to desalination plants. A SWGEN is proposed, which is based on parametric Markov-Switching Auto-Regressive (MSAR) models and is capable to simulate realistic hourly multivariate time series of solar irradiance, temperature and wind speed of the target installation site. Numerical results are presented, demonstrating that: (i) SWGENs enable to evaluate the reliability of RES-based desalination plants during their operation over a 20 years lifetime period and (ii) using an appropriate time series simulated with a SWGEN as input to the design optimization process results in a RES-based desalination plant configuration with higher reliability compared to the configurations derived when the other types of meteorological datasets are used as input to the design optimization process.
RESSWGEN(6).pdf (3.69 Mo) Télécharger le fichier
hal-02425916 , version 1 (31-12-2019)
Pierre Ailliot, Marie Boutigny, Eftichis Koutroulis, Athanasios Malisovas, Valérie Monbet. Stochastic weather generator for the design and reliability evaluation of desalination systems with Renewable Energy Sources. Renewable Energy, 2020, 158, pp.541-553. ⟨10.1016/j.renene.2020.05.076⟩. ⟨hal-02425916⟩
111 Consultations
126 Téléchargements
