Multi-arm, multi-stage randomised controlled trials for evaluating therapeutic HIV cure interventions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Lancet HIV Année : 2019
The evaluation of immune-based approaches to achieve an antiretroviral therapy free remission of HIV infection requires proven efficacy through antiretroviral therapy interruption placebo-controlled trials. This approach is not without risk to participants and innovative trial designs need to be developed that minimise the number of participants treated with placebo and ineffective candidates. Multi-arm, multi-stage (MAMS) trial designs can be used in this context to accelerate the development of an immune-based therapeutic agent for HIV cure. Issues related to implementing a MAMS design within the planned EHVA T01 trial are considered here. EHVA T01 is a multicentre, MAMS, double-blind, phase 1 and 2 trial that aims to evaluate the effect of immune interventions on viral control in HIV-1 infected participants following analytic treatment interruption. The application of a MAMS design increases the likelihood that the EHVA T01 trial will identify a successful treatment and minimises the number of participants undergoing analytical treatment interruptions who have been treated with futile agents. The use of a MAMS design is a promising strategy to evaluate complex immune-based approaches aimed at curing HIV-infection, particularly relevant to the pipeline with multiple agents requiring examination.
BPH_Lancet_Moore_2019.pdf (773.29 Ko) Télécharger le fichier
hal-02426904 , version 1 (02-01-2020)
hal-02426904 , version 2 (05-03-2021)
Cecilia Moore, Wolfgang Stohr, Laura Richert, Jean-Daniel Lelievre, Angela Crook, et al.. Multi-arm, multi-stage randomised controlled trials for evaluating therapeutic HIV cure interventions. The Lancet HIV, 2019, 6 (5), pp.e334-e340. ⟨10.1016/s2352-3018(19)30082-7⟩. ⟨hal-02426904v2⟩
116 Consultations
317 Téléchargements
