Upper bounds for the function solution of the homogenuous 2D Boltzmann equation with hard potential - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Annals of Applied Probability Année : 2019
We deal with $f_{t}(dv),$ the solution of the homogeneous $2D$ Boltzmann equation without cutoff. The initial condition $f_{0}(dv)$ may be any probability distribution (except a Dirac mass). However, for sufficiently hard potentials, the semigroup has a regularization property (see \cite{[BF]}): $f_{t}(dv)=f_{t}(v)dv$ for every $t>0.$ The aim of this paper is to give upper bounds for $f_{t}(v),$ the most significant one being of type $f_{t}(v)\leq Ct^{-\eta}e^{-\left\vert v\right\vert ^{\lambda}}$ for some $\eta,\lambda>0.$
AAP24April2018.pdf (270.64 Ko) Télécharger le fichier
hal-02429468 , version 2 (29-09-2017)
hal-02429468 , version 3 (02-05-2018)
hal-02429468 , version 1 (06-01-2020)
Vlad Bally. Upper bounds for the function solution of the homogenuous 2D Boltzmann equation with hard potential. The Annals of Applied Probability, 2019. ⟨hal-02429468v3⟩
750 Consultations
339 Téléchargements
