Regularization lemmas and convergence in total variation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Journal of Probability Année : 2020
We provide a simple abstract formalism of integration by parts under which we obtain some regularization lemmas. These lemmas apply to any sequence of random variables (F n) which are smooth and non-degenerated in some sense and enable one to upgrade the distance of convergence from smooth Wasserstein distances to total variation in a quantitative way. This is a well studied topic and one can consult for instance [2, 10, 13, 20] and the references therein for an overview of this issue. Each of the aforementioned references share the fact that some non-degeneracy is required along the whole sequence. We provide here the first result removing this costly assumption as we require only non-degeneracy at the limit. The price to pay is to control the smooth Wasserstein distance between the Malliavin matrix of the sequence and the Malliavin matrix of the limit which is particularly easy in the context of Gaussian limit as their Malliavin matrix is deterministic. We then recover, in a slightly weaker form, the main findings of [18]. Another application concerns the approximation of the semi-group of a diffusion process by the Euler scheme in a quantitative way and under the Hörmander condition.
RegLemmaVar-18-09-2019.pdf (355.83 Ko) Télécharger le fichier
hal-02429512 , version 1 (06-01-2020)
Vlad Bally, Lucia Caramellino, Guillaume Poly. Regularization lemmas and convergence in total variation. Electronic Journal of Probability, 2020, 25, paper no. 74, 20 pp. ⟨10.1214/20-EJP481⟩. ⟨hal-02429512⟩
139 Consultations
120 Téléchargements
