Bison: Instantiating the Whitened Swap-Or-Not Construction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Anne Canteaut
Virginie Lallemand
Gregor Leander
  • Fonction : Auteur
  • PersonId : 857582
Patrick Neumann
  • Fonction : Auteur
  • PersonId : 1062409
Friedrich Wiemer
  • Fonction : Auteur
  • PersonId : 1062410
We give the first practical instance-bison-of the Whitened Swap-Or-Not construction. After clarifying inherent limitations of the construction, we point out that this way of building block ciphers allows easy and very strong arguments against differential attacks.
bison2019.pdf (1.18 Mo) Télécharger le fichier
hal-02431714 , version 1 (08-01-2020)
Paternité
Anne Canteaut, Virginie Lallemand, Gregor Leander, Patrick Neumann, Friedrich Wiemer. Bison: Instantiating the Whitened Swap-Or-Not Construction. Eurocrypt 2019 - 38th Annual International Conference on the Theory and Applications of Cryptographic Techniques, May 2019, Darmstadt, Germany. ⟨10.1007/978-3-030-17659-4_20⟩. ⟨hal-02431714⟩
Collections
INRIA INRIA2
84 Consultations
107 Téléchargements
