Modeling and analysis of an Absorption Column Connected to a Microalgae Culture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Applied Mathematics Année : 2020
We build and analyze a mathematical model of a system for biogas upgrading: an absorption column connected to a microalgae culture. The construction of the model is based on a chemical engineering approach and classical models of microalgae cultures. In our analysis, we prove the existence and uniqueness of solutions of a boundary value problem describing the absorption column. Some properties of this solution are also proved. Then, we use these results to study the long-term behavior of the mathematical model describing the coupled system. We state sufficient conditions for the existence of a globally attracting steady state characterized by the presence of microalgae. Finally, we find numerically the steady states of the system to test the efficiency of the system for purifying biogas.
manuscript.pdf (622.08 Ko) Télécharger le fichier
hal-02432325 , version 1 (08-01-2020)
Carlos Martinez, Francis Mairet, Leslie Meier, David Jeison, Andrés Avila. Modeling and analysis of an Absorption Column Connected to a Microalgae Culture. SIAM Journal on Applied Mathematics, 2020, 80 (2), ⟨10.1137/18M1225641⟩. ⟨hal-02432325⟩
110 Consultations
184 Téléchargements
