Degree and height estimates for modular equations on PEL Shimura varieties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the London Mathematical Society Année : 2022
We define modular equations in the setting of PEL Shimura varieties as equations describing Hecke correspondences, and prove upper bounds on their degrees and heights. This extends known results about elliptic modular polynomials, and implies complexity bounds for number-theoretic algorithms using these modular equations. In particular, we obtain tight degree bounds for modular equations of Siegel and Hilbert type for abelian surfaces.
heights-modpol.pdf (561.56 Ko) Télécharger le fichier
hal-02436057 , version 1 (12-01-2020)
hal-02436057 , version 2 (06-03-2020)
hal-02436057 , version 3 (14-05-2021)
hal-02436057 , version 4 (16-08-2021)
Jean Kieffer. Degree and height estimates for modular equations on PEL Shimura varieties. Journal of the London Mathematical Society, 2022, 105 (2), pp.1314-1361. ⟨10.1112/jlms.12540⟩. ⟨hal-02436057v4⟩
186 Consultations
134 Téléchargements
