Methodological Design for Integration of Human EEG Data with Behavioral Analyses into Human-Human/Robot Interactions in a Real-World Context
Analysis of human activities is a complex task that needs multifactorial considerations. So an electroencephalographic (EEG) data analysis can be improved by a conjunction of devices that monitor time courses of multiple types of physiological factors of the subject and counterparts when interactions are ongoing in the environment. In this article, we proposed a method to provide the complementary hardware and software treatment that associate devices to be able to synchronize simultaneous data recording to fit the high sampling rate of the EEG signal, such as more than 512 Hz. This method of synchronizing physiological data gathered from three different devices through the use of trigger signals is crucial for an accurate post-analysis and was validated in the experiment. The proposed method is widely applicable in various cases accompanied with EEG measurements and offer a wide possibility in device developments for rehabilitation and communications.
[ICICIC2019-SS19-03] Methodological Design for Integration of Human EEG Data with Behavioral Analyses_v4.pdf (411.49 Ko)
Télécharger le fichier
