Long-Range Wireless Radio Technologies: A Survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Future internet Année : 2020
Wireless networks are now a part of the everyday life of many people and are used for many applications. Recently, new technologies that enable low-power and long-range communications have emerged. These technologies, in opposition to more traditional communication technologies rather defined as "short range", allow kilometer-wide wireless communications. Long-range technologies are used to form Low-Power Wide-Area Networks (LPWAN). Many LPWAN technologies are available, and they offer different performances, business models etc., answering different applications' needs. This makes it hard to find the right tool for a specific use case. In this article, we present a survey about the long-range technologies available presently as well as the technical characteristics they offer. Then we propose a discussion about the energy consumption of each alternative and which one may be most adapted depending on the use case requirements and expectations, as well as guidelines to choose the best suited technology.
futureinternet-12-00013.pdf (1.69 Mo) Télécharger le fichier
hal-02440409 , version 1 (15-01-2020)
Brandon Foubert, Nathalie Mitton. Long-Range Wireless Radio Technologies: A Survey. Future internet, 2020, 12 (1), pp.13. ⟨10.3390/fi12010013⟩. ⟨hal-02440409⟩
235 Consultations
565 Téléchargements
