UAV Set Covering Problem for Emergency Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recent technology allows UAVs to be implemented not only in fields of military, videography, or logistics but also in a social security area, especially for disaster management. UAVs can mount a router and provide a wireless network to the survivors in the network-shadowed area. In this paper, a set covering problem reflecting the characteristics of UAV is defined with a mathematical formulation. An extended formulation and branch-and-price algorithm are proposed for efficient computation. We demonstrated the capability of the proposed algorithm with a computational experiment.
489108_1_En_10_Chapter.pdf (213.64 Ko) Télécharger le fichier
hal-02460476 , version 1 (30-01-2020)
Paternité
Youngsoo Park, Ilkyeong Moon. UAV Set Covering Problem for Emergency Network. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2019, Austin, TX, United States. pp.84-90, ⟨10.1007/978-3-030-29996-5_10⟩. ⟨hal-02460476⟩
68 Consultations
34 Téléchargements
