On the Use of Attention Mechanism in a Seq2Seq based Approach for Off-line Handwritten Digit String Recognition
In this work, we investigate the use of the attention mechanism in deep learning for a better reading of handwritten digit strings in digitized images. The proposed recognition system built upon a CNN (Convolutional Neural Network) and two RNNs (Recurrent Neural Networks), acting as Encoder and Decoder and using the attention mechanism. We used a 1D mechanism for attention location with a "soft" alignment attention which has the peculiarity of having an easily calculable gradient and thus to integrate well with the network. Experimental results on data from ORAND-CAR A, ORAND-CAR B and CVL HDS databases compare favorably to other published methods.
