HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Hierarchy Builder: algebraic hierarchies made easy in Coq with Elpi
Abstract : It is nowadays customary to organize libraries of machine checked proofs around hierarchies of algebraic structures [2, 6, 8, 16, 18, 23, 27]. One influential example is the Mathematical Components library on top of which the long and intricate proof of the Odd Order Theorem could be fully formalized [14]. Still, building algebraic hierarchies in a proof assistant such as Coq [9] requires a lot of manual labor and often a deep expertise in the internals of the prover [13, 17]. Moreover, according to our experience [26], making a hierarchy evolve without causing breakage in client code is equally tricky: even a simple refactoring such as splitting a structure into two simpler ones is hard to get right. In this paper we describe HB, a high level language to build hierarchies of algebraic structures and to make these hierarchies evolve without breaking user code. The key concepts are the ones of factory, builder and abbreviation that let the hierarchy developer describe an actual interface for their library. Behind that interface the developer can provide appropriate code to ensure retro compatibility. We implement the HB language in the hierarchy-builder addon for the Coq system using the Elpi [11, 28] extension language.
Complete list of metadata
Cited literature [26 references]  Display  Hide  Download
https://hal.inria.fr/hal-02478907
Contributor : Cyril Cohen Connect in order to contact the contributor
Submitted on : Wednesday, May 6, 2020 - 12:38:48 PM
Last modification on : Friday, February 4, 2022 - 3:22:17 AM
File
hb.pdf
Identifiers
Collections
Citation
Cyril Cohen, Kazuhiko Sakaguchi, Enrico Tassi. Hierarchy Builder: algebraic hierarchies made easy in Coq with Elpi. FSCD 2020 - 5th International Conference on Formal Structures for Computation and Deduction, Jun 2020, Paris, France. pp.34:1--34:21, ⟨10.4230/LIPIcs.FSCD.2020.34⟩. ⟨hal-02478907v5⟩
Share
Metrics
Record views
1029
Files downloads
833
