Modelling pattern formation through differential repulsion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Networks and Heterogeneous Media Année : 2020
Motivated by experiments on cell segregation, we present a two-species model of interacting particles, aiming at a quantitative description of this phenomenon. Under precise scaling hypothesis, we derive from the microscopic model a macroscopic one and we analyze it. In particular, we determine the range of parameters for which segregation is expected. We compare our analytical results and numerical simulations of the macroscopic model to direct simulations of the particles, and comment on possible links with experiments.
1906.00704.pdf (8.24 Mo) Télécharger le fichier
hal-02499520 , version 1 (05-03-2020)
Julien Barre, Pierre Degond, Diane Peurichard, Ewelina Zatorska. Modelling pattern formation through differential repulsion. Networks and Heterogeneous Media, 2020, 15 (3), pp.307-352. ⟨10.3934/nhm.2020021⟩. ⟨hal-02499520⟩
71 Consultations
26 Téléchargements
