The hitchhiker's guide to decidability and complexity of equivalence properties in security protocols (technical report) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2020
Vincent Cheval
Steve Kremer
Privacy-preserving security properties in cryptographic protocols are typically modelled by observational equivalences in process calculi such as the applied pi-calulus. We survey decidability and complexity results for the automated verification of such equivalences , casting existing results in a common framework which allows for a precise comparison. This uni ed view, beyond providing a clearer insight on the current state of the art, allowed us to identify some variations in the statements of the decision problems – sometimes resulting in different complexity results. Additionally, we prove a couple of novel or strengthened results.
survey.pdf (770.06 Ko) Télécharger le fichier
hal-02501577 , version 1 (09-03-2020)
hal-02501577 , version 2 (01-04-2020)
hal-02501577 , version 3 (22-04-2020)
hal-02501577 , version 4 (25-05-2020)
  • HAL Id : hal-02501577 , version 4
Vincent Cheval, Steve Kremer, Itsaka Rakotonirina. The hitchhiker's guide to decidability and complexity of equivalence properties in security protocols (technical report). [Technical Report] Inria Nancy Grand-Est. 2020. ⟨hal-02501577v4⟩
183 Consultations
177 Téléchargements
