Abstract : Models play an essential role in the design process of cyber-physical systems. They form the basis for simulation and analysis and help in identifying design problems as early as possible. However, the construction of models that comprise physical and digital behavior is challenging. Therefore, there is considerable interest in learning such hybrid behavior by means of machine learning which requires sufficient and representative training data covering the behavior of the physical system adequately. In this work, we exploit a combination of automata learning and model-based testing to generate sufficient training data fully automatically.Experimental results on a platooning scenario show that recurrent neural networks learned with this data achieved significantly better results compared to models learned from randomly generated data. In particular, the classification error for crash detection is reduced by a factor of five and a similar F1-score is obtained with up to three orders of magnitude fewer training samples.
https://hal.inria.fr/hal-02526358 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, March 31, 2020 - 3:14:31 PM Last modification on : Tuesday, March 31, 2020 - 3:41:47 PM
Bernhard K. Aichernig, Roderick Bloem, Masoud Ebrahimi, Martin Horn, Franz Pernkopf, et al.. Learning a Behavior Model of Hybrid Systems Through Combining Model-Based Testing and Machine Learning. 31th IFIP International Conference on Testing Software and Systems (ICTSS), Oct 2019, Paris, France. pp.3-21, ⟨10.1007/978-3-030-31280-0_1⟩. ⟨hal-02526358⟩
