A Linear Time Algorithm Computing the Optimal Speeds Minimizing Energy Under Real-Time Constraints - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2020
(1) , (2) , (2)
1
2
RR-9339.pdf (878.84 Ko) Télécharger le fichier
Dates and versions
hal-02540230 , version 1 (10-04-2020)
Identifiers
  • HAL Id : hal-02540230 , version 1
Cite
Bruno Gaujal, Alain Girault, Stéphan Plassart. A Linear Time Algorithm Computing the Optimal Speeds Minimizing Energy Under Real-Time Constraints. [Research Report] RR-9339, Inria Grenoble Rhône-Alpes. 2020. ⟨hal-02540230⟩
67 View
204 Download
Share
