Shared Gaze While Driving: How Drivers Can Be Supported by an LED-Visualization of the Front-Seat Passenger’s Gaze - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Benedikt Streitwieser
  • Fonction : Auteur
  • PersonId : 1068206
Alexander Meschtscherjakov
  • Fonction : Auteur
  • PersonId : 1017005
Manfred Tscheligi
  • Fonction : Auteur
  • PersonId : 989528
The front-seat passenger in a vehicle may assist a driver in providing hints towards points of interest in a driving situation. In order to communicate spatial information efficiently, the so-called shared gaze approach has been introduced in previous research. Thereby, the gaze of the front-seat passenger is visualized for the driver. So far, this approach has been solely investigated in driving simulator environments. In this paper, we present a study on how well shared gaze works in a real driving situation (n = 8). We examine identification rates of different object types in the driving environment based on the visualization of the front-seat passenger’s gaze via glowing LEDs on an LED-strip. Our results show that this rate is dependent on object relevance for the driving task and movement of the object. We found that perceived visual distraction was low and that the usefulness of shared gaze for navigational tasks was considered high.
488591_1_En_21_Chapter.pdf (1.63 Mo) Télécharger le fichier
hal-02544629 , version 1 (16-04-2020)
Paternité
Sandra Trösterer, Benedikt Streitwieser, Alexander Meschtscherjakov, Manfred Tscheligi. Shared Gaze While Driving: How Drivers Can Be Supported by an LED-Visualization of the Front-Seat Passenger’s Gaze. 17th IFIP Conference on Human-Computer Interaction (INTERACT), Sep 2019, Paphos, Cyprus. pp.329-350, ⟨10.1007/978-3-030-29384-0_21⟩. ⟨hal-02544629⟩
43 Consultations
40 Téléchargements
