Preprints, Working Papers, ...
Sub-Weibull distributions: generalizing sub-Gaussian and sub-Exponential properties to heavier-tailed distributions
Abstract : We propose the notion of sub-Weibull distributions, which are characterised by tails lighter than (or equally light as) the right tail of a Weibull distribution. This novel class generalises the sub-Gaussian and sub-Exponential families to potentially heavier-tailed distributions. Sub-Weibull distributions are parameterized by a positive tail index θ and reduce to sub-Gaussian distributions for θ = 1/2 and to sub-Exponential distributions for θ = 1. A characterisation of the sub-Weibull property based on moments and on the moment generating function is provided and properties of the class are studied. An estimation procedure for the tail parameter is proposed and is applied to an example stemming from Bayesian deep learning.
Document type :
Complete list of metadatas
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-02545121
Contributor : Mariia Vladimirova <>
Submitted on : Thursday, April 16, 2020 - 5:51:31 PM
Last modification on : Tuesday, November 24, 2020 - 4:00:09 PM
File
paper_2020_Sub_Weibull_HAL.pdf
Identifiers
  • HAL Id : hal-02545121, version 1
Collections
Citation
Mariia Vladimirova, Stéphane Girard, Hien Nguyen, Julyan Arbel. Sub-Weibull distributions: generalizing sub-Gaussian and sub-Exponential properties to heavier-tailed distributions. 2020. ⟨hal-02545121⟩
Share
Metrics
Record views
93
Files downloads
375
